bypassing the radiator and then some
runnyrunnerton
one or two guys doing that
remote auto tranny filter?
Yes- over on Yota Tech this is always a big discussion topic- the external tranny cooler idea and at least one or 2 guys over there favor using a screw on type of oil filter for the tranny fluid.
Good luck with your project but for others following along I would simply recommend replacement of the factory radiator. Lot less plumbing involved and the KOYO A1998 is highly recommended and a direct bolt up application.
We did this for my friend's 01 Limited and now feel satisfied that for another 8-10 years there will be no worries whatsoever.
:iagree:
I have been looking at the external cooler but have been hesitant, do to the plumbing, mounting and air flow issues. This is the first I have seen of this KOYO A1998 this is the way I will be going and in the near future thanks for the info.
I recently replaced the old radiator with the Koyo. I then had a tranny shop put a tru cool cooler on. The radiator was pretty easy to do, and if I had it to do over, I would have just added the aux tranny cooler myself because it is simple ( I mainly had them do it because they were changing the fluid so it was a logical time to do the cooler). I'm glad the tranny fluid goes through both, because on high mountain passes out here the fluid still gets to about 220 degrees. The tranny cooler is mounted right in front and in the middle of the grill area.
