Any guesstimate on the combined weight of the bumper and winch? maybe a range? Wondering if the combo could trigger the need for a higher weight spring up front that's all.
Is the bullbar to be used as a recovery point? or as protection of the bumper?
debating on whether to get the bullbar or not...
Still wanting one of these so bad. Anybody with a body lift try to install one yet? I'm assuming with bumper stretch it may be fine with a 1" or maybe a little gap above?
Mine was only 425 and I picked it up, so I dont know what it would be to ship. But it is a weld together kit from NWTI.
So my Lo-Pro bumper will be here Monday!! Outside of sandblasting, what would be the best/easiest method of prep sanding for this thing? Angle grinder with wire wheel?
Caleb does awsome work! Im glad this bummper is starting to grab tracation.
I've got the '06-'09 lo-profile C4Fab bumper along with a CBI front skid. My CBI skid is for a V8 and diff drop and it all fits fine. I say that because the bumper went on well and the skid wasn't in the way. I don't have any pictures of the two together but I do remember completing the last steps of the bumper install and seeing the two and liking how the factory gap was now covered with steel.
For those getting the '06-'09 bumper and maybe even the earlier model, I have one item to add to the install instructions. Remove the metal filler piece below the headlights. They come off very easily and by removing them the factory bumper will reinstall much easier and you will avoid scratching up your fender flares :bash:
They are 275/70/17 BFG AT's. I'm also running a 1" Bora wheel spacer.
Curious...if the bumper/winch combo is around 150 lbs, is a front suspension upgrade necessary? My truck is on the original (and still fully functional) XREAS.
[MENTION=131444]C4 Fabrication[/MENTION], terrific job of designing these. Frankly, I haven’t considered a bumper because the full-build types that look like they belong on an MRAP don’t appeal to me. These could be OEM by the look. Nice work.
A suspension upgrade doesn't necessarily "need" to be done, but the weight will cause the front of your 4runner to sag down 1/2"-3/4" in most cases.
Typically most 4runners and Tacoma's are already sitting low in the front so people put a lift on the front to compensate for the weight and get the vehicle sitting level again.
Do you know if there is enough room behind the bull bar for mounting a High lift? Is this even an OK Idea?
Boort
