Ca. Smog Test Results.. Gross Polluter
MARCOAWG
1990 v-6 4runner
Did the following and failed twice.
major tune up.
replaced CAT & muffler ( muf was Holy)
think i'll do the Oxygen sensor next , I found one before the CAT ... but where is the other one?
Also it smells like i'm burning oil..
If I put denatured alcohol will that work?
Well if you are burning oil that may be a more serious and expensive problem like worn rings. But I would make sure it is timed right first. My truck failed the hydrocarbon test with a reading of 300. i went back and replaced cap rotor, wires, plugs and it still failed, but the guy doing the test pointed that my truck was missing a lot and just turned the dist and made it stop missing and it passed with a reading of 30.
