Cab Noise 95
4running1990
I know there is really no cure but does anyone have any suggestions of how i can make it quieter in the cab? Most of the noise sounds like it coming from the doors. Any way to tighten things up?
hi there is a few things you can do to make the cab quieter the first thing is to make sure there are no holes in your firewall ie gromets warn out or missing, cable, wiring rubbers in good condition. another thing is behind all door cards there is a sheet of plastic between the door and the door card make sure they are still there and no tears and are sealed against the door. the other thing you can do is use felt under carpet, paint external panels behind internal panels with bituman paint. all are easy to do but will take some time to do but worth it cheers
