Kurt Franz
Hello,
First time here ..... hopefully someone can shed some light on this one:
I have 2 4Runners - a 1990 model that has the 31" tire package with 4:56 gears and a 1994 model that is plain jane from California with whatever stock gearing came on that year model and 30 inch tires. I am fairly certain that it is not 4:56 though.
When driving the 1990 at 70 mph I am right around 2400 RPM
When driving the 1994 at 70 mph I am a right about 3000 RPM
I realize that the tire size differences will have an impact, but not to this extent.
Also, on the 1990 the rpm drops more in overdrive than the 1994 does.
So, I am wondering - did toyoya do something to California vehicles with regards to gearing/shift points or something to make the engine rev higher and hence hotter to burn off more emissions or something?
Last year on a trip in the 1990 I set the cruise control at 65 mph and got a tad over 300 miles on a tank of gas
On another trip in the 1994 I set the cruise at 62 mph and the best I got was 220 miles on a tank of gas.
Also I notice that on the 1990 when overdrive kicks in the rpms drop about 600-700 rpm, but on the 1994 the drop is only about 400 rpm. What gives here?
My speedometers are correct on both vehicles.
Both vehicles are stock with no performance modifications.
Both vehicles are tuned properly and running properly
In summary, It would seem that all things considered, the 1994 should get better mileage than the 1990 due to the higher gearing - regardless of the 1 inch tire size difference.
My theory is that the CA emissions are causing the issues, but I can't confirm this. Hoping someone can chime in with some real facts about this, and also with a possible workaround if necessary.
Best,
Kurt F
Best,
Kurt F
