cam bolt seized
Ther00ster
I'm getting ready to lift my truck... I want to get the parts I need just in case my cam bolts are seized. But how many Quantities will I need for each LCR? I'm I missing a part number also?
48198-60011
48452-35020
48198-60011
There's 2 bolts for each control arm. If you're buying the pieces individually like that then you'll need 4 48198-60011, and 4 48452-35020 to do both control arms. Make sure you use a bunch of anti seize on them too. You may also need the actual bolt itself that goes through the cam sleeve into the adjuster nut on the back. (#16 & #19) You can see everything here. http://toyotapartsestore.com/2007-t...s-suspension_parts-lower_control_arm-8416225/
8416225.SVG
There's 2 bolts for each control arm. If you're buying the pieces individually like that then you'll need 4 48198-60011, and 4 48452-35020 to do both control arms. Make sure you use a bunch of anti seize on them too. You may also need the actual bolt itself that goes through the cam sleeve into the adjuster nut on the back. (#16 & #19) You can see everything here. 2007 Toyota 4Runner Suspension Parts lower control arm parts - OEM Toyota Parts
8416225.SVG
Thanks man
This is wrong.
Front and rear camber bolts are different.
Front bolts are 3 pieces/parts and rear bolts are 3 pieces/parts.
This is what I bought to replace my two lower control arms on my 2007 4RUNNER. I attached a picture below to make sure you get what you need.
x1 - 4806860010 ARM SUB-ASSEMBLY, FRONT SUSPENSION, LOWER No.1 RIGHT $321.67
x1 - 4806960010 ARM SUB-ASSEMBLY, FRONT SUSPENSION, LOWER No.1 LEFT $321.67
x2 - 4819060020 CAM ASSEMBLY, CAMBER ADJUST; CAM, FRONT SUSPENSION CAMBER ADJUST, No.1 LEFT; CAM, FRONT SUSPENSION CAMBER ADJUST, No.1 RIGHT $21.08
x2 - 4819860011 CAM, CAMBER ADJUST, No.2; CAM, FRONT SUSPENSION CAMBER ADJUST, No.2 LEFT; CAM, FRONT SUSPENSION CAMBER ADJUST, No.2 RIGHT $20.34
x2 - 4840960020 CAM SUB-ASSEMBLY, FRONT SUSPENSION TOE ADJUST $26.78
x2 - 4845235020 PLATE, FRONT SUSPENSION TOE ADJUST, No.2 $28.52
Thank man this is what I'm looking for
Here is a view with one put together and one took apart beside it.
Also, I'll sell you this set for $50.
If the OP isn't interested in these, please get me a shipped price to 64156. The last time I had my truck in for an alignment, they said three of my cam bolts are frozen.
When I went to get an alignment after I bought my truck 2 months ago 2 of mine were seized on the passenger side from winters up in Maine. All original parts from 05 and 160k miles.
I got it aligned as best as possible and afterwards I soaked the lower bushings and bolts where they meet the lower control arms with PB Blaster every couple days for 2 weeks. When I went back to the alignment place a month later, everything was movable again and i got it all aligned within spec!
It just takes some time and patience and they'll come loose.
By the way, go to Firestone and buy the lifetime alignment, you can go back as many times you want as long as you own the vehicle for $169. Totally worth it
So just wanted to post a update on the post... these are all the parts to need to replace the low cams on both sides front and back
48190-60020 adjust cam x2
48198-60011 adjust cam x2
48409-60020 lower control arm plate x2
48452-35020 lower control arm bolt x2
90119-14069 control arm nut x2
Good to hear as I haven't tried yet but being a 10 year old boston truck, i'm expecting the worst. I just bought an air hammer to try and knock them loose.
