First of all thanks fopr your help.
That's what my chilton's manual says but, I could of sworn I took it apart with one dot together. If I put two dots together then the timing belt sprocket won't be at TDC, it will be upside down. I'm scared to install it wrong because I've seen Broken valves and rocker arms before.
The Chiltons manual also says that I have a 5VZE engine without the intake manifold and DOHC. I don't get it. This shit is pissing me off. In the chiltons it again, shows the 3VZE with the intake and SOHC. WTF?
I have been thinking about this alot I will never take apart this motor again. F this truck's design. the Timing belt tensioner OMG remove the Brush gaurd and the A/C motor are you kidding me!
