Camber Adjustment
brianhuntRVA
Can one adjust only the camber using the LCA eccentric bolts? Or will that also effect the toe?
Background: I had it aligned after I installed my lift, this was a couple months ago. Shop said they got it as close as they could. I am noticing a bit more wear on the outside of the front tires. I looked under there yesterday out of curiosity and it looks like I can push the arm out just a bit more.
Alignment adjustments are something you absolutely should not do yourself. Especially camber and caster. Even if you were to shade tree it at minimum you should have a set of gauges.
MaximussK
