camshaft bolt hole dethreaded
Hi
5VZ - one of the bolts on my cam cap wont torque, the slot is dethreaded. Luckily (I think) it is the cap covering the cam seal/cap and there's no shaft underneath it.
I was recommended to use a time-sert, which I have never used before. I've also heard the threads extend past the length of the cap bolt and a stud + nut will work. Any idea where I could find such a stud?
Thanks guys
I've used these many times to repair the coil on plug thread (pass side valve cover) with great success and many other stripped holes! Just don't drill to deep. Just be careful of drill and tap chips falling into the engine.
I also have used time-serts, both have been successful.
https://a.co/d/2cO5PuK
Just make sure the thread size before ordering. I think it's a M6 x 1.0 but I could be wrong.
Das ist eine knifflige Situation, besonders bei einer Nockenwellen-Schraube. Wenn das Gewinde beschädigt ist, ist ein Reparatureinsatz meist die bessere Lösung. Während ich solche Probleme bearbeite, mache ich gelegentlich Pausen und entspanne mich kurz mit etwas Einfachem wie Book of Ra Deluxe, bevor ich weitermache.
The bolt appears to be 7mm x 1.0. I don't really want to drill into my cylinder head, can I just use a 6mm helicoil kit and a 6mm bolt of the same length instead?
AndiGarage
