Can a remote start be used with existing remote transmitter?
atomic punk
I have keyless entry, but not the stock alarm...
Due to many reasons, I am seriously considering purchasing the 4R stock alarm on ebay and installing it myself.
However, I would like to have a remote starter installed (maybe an aftermarket pro install), and I'm wonding if the stock 4R transmitter can be used as a remote starter also? In other words, is there another, unused channel in that transmitter?
Or, does toyota make a remote starter for it?
Thanks....
There is a remote starter that is an Official Toyota Accessory item (however, it is manufactured for the Hilux Surf), but is a plug and play installation in the US Spec T4R.
I have thought about purchasing this item, many times over. It is $475.00 - however, I am currently saving my money up for another modification (designed for the Hilux Surf) that will be a surprise.
With the Hilux Surf OEM Toyota Remote Starter, you would still need a Imobilizer bypass and would loose a key. Now, I thought about getting a key made for this purpose - where I would cut off the metal so the only thing that would be inside the bypass box would be the transmitter.
I have also been throwing the thought around about modifying my rig to have a fuel pump cut off switch.
There are remote starts available that work with the stock remote. I think you push the 'lock' button twice to start. Not a Toyota part.
I like the concept..... but $250 ... w/o installation????
There's got to be something less expensive out there that can use the factory transmitter.
I don't have the factory alarm, but I want that too, and I'm "guessing" that a factory alarm must be $300 w/o installation... that's $550... I can get a Viper and remote start installed for just over $600, but I don't want all those horn sounds when arming/disarming. I'm used to the beeps and want to keep them. (call me a phag if you want, but the horn is annoying in my quiet 'hood) ;):
Just got off the phone with the local stealership.... they outsource their alarm installs (obviously) and the quotes are as follows:
...with keyless entry system already in vehicle:
Factory alarm: $369
Factory alarm + remote starter: $459
I think I might go with that. No compatibility worries, no installing myself, no hassles....and I think I can keep the same transmitter, with the rear window function too.
Any thoughts?
I'd make SURE they clarify that it uses your existing remotes - that's my main goal too and I don't plan to settle for anything else.
Factory alarm: $369
Any thoughts?
if its $459 for the RS3200+ and a remote starter then thats a good deal, my local stealership was asking for something like $800, for that I'd rather have a top of the line Python.
