I'm changing front pads and rotors. I've got wheels off, calipers out of the way. Rotors are supposed to slide off, right? What am I forgetting?
Sometimes the small screw holding the rotor to the hub is still in place. You might have to take a closer look to see if the philips head screw is there. It sits flush with the rotor so it may not be easy to spot.
I don't think 4wd has that screw? I didn't remove any screws last time when I did the Tundra brake upgrade.
What screw? I just did the TBU 2 weeks ago and there is no screw on the rotors.
I had to use a technique like the one shown in this video last time I removed my rotors....BFH would not do the trick....this is much more elegant...
https://www.youtube.com/watch?v=mtsTJCRljAs&t=242s
Buckaroo
Most people don't put the screws back in after the first rotor replacement. Unless you're the first owner and never replaced the rotor, its most likely been removed. Yet, I could be wrong these trucks never came with screws on the rotors but that's unlikely.
Been beating the hell out of it with a BFH. If my rotors weren't warped before, they sure are now.
