cant get front diff (CV) oil seal to not leak...pls help on this
cordrayj1
ive put a new oil seal in the passenger side of my 4runner. and im now depressed that i cant seem to get it seated correctly. after putting a brand new one in it came out even faster than before with the bad one. . . anyone have any advice on this?
please help. this smell of gear oil is gettin INTENSE
Buy a new seal and try again. Maybe invest in a seal driver too. It will help keep things square.
no offense singtoe. . . thats kind of obvious. looking for more of a procedural approach to this one. as in . ..
does all grease need to be cleaned from inside diff tube to prevent leakage? (so seal wont slip inside the diff tube)
do any special things need to be done as far as the actual installation goes. . .
Not to offer offense but it is what it is.
diffsea.png~original
guess i just knocked it in too far. the FSM i was using had no specs on that 5.5mm crap. hopefully this'll solve it.
Cordrjay1,
Have you resolved this issue yet? I am having the same problem with my passenger side front diff/CV seal on my 98 limited. Started leaking after replacing the CV axle with a Napa Auto rebuilt unit.
I've replaced the seal 2 times, being very careful to adhere to the correct 5.5mm depth. Replaced it last night, filled diff to bottom of fill port on flat ground and it still leaking today.
Any other suggestions?
Thanks.
yeah its been resolved.i very, very carefully tapped it in with the extension tube from my shop vac which fit perfect around the inner flexible lip. i then coated outer portion w some grease and drove in. make sure the dust shield on the cv is not bent. and pay attention to not let it fall on the seal after you have placed the shaft in the diff just prior to knocking it in. . . shoot me a pm and ill give you my phone # if you have other issues.
BillM777
