I figured I would add to this existing thread instead of starting my own in order to add context. In my case, I don't hear any noise and the second or third time I try to depress the brake it works. But twice now this week I wasn't able to stop right away and it's a little scary. I can't have my family in the truck till this is fixed. If the problem is intermittent do you guys still think it's the brake booster?
Describing how it feels would help.
Feels hard? When you feel the resistance does it feel higher off the floor or same as before?
Feels soft and goes down to floor?
Same thing happened to me, it ended up locking my brakes I had to bleed the brakes to get it home. It was the master cylinder. I replaced it with a cheap one from Autozone/Oreillys and about a year later same thing happened. I bought an Aisin after that and no problems in about 10 years.
Just an FYI I never touched the booster
Thanks for the info. Was your problem intermittent or did it just lock up out of the blue straight away with no warning signs?
How much was the master cylinder and how was the install?
It was out of the blue. I was driving around and truck was slowing i had to downshift and like you engine was bogging down. Finally got to the point where it stalled. I was dumbfounded, i ended up bleeding brakes. Drove it home and had to stop and bleed em another time before i made it there.
Its not hard at all, just make sure you bench bleed it. Cost me close to $100 if i remember right, for the Aisin MC
You could actually upgrade to a 90s pickup MC the bore is bigger and will give you a little more stopping power. There are many threads on it, here and yotatech if you wanna research it
I got mine from amazon. Not sure just go by your year make trim etc. try rockauto as well
