Cartrimhome.com dome LED smoke and fire
Senior Member
LED panels for dome light that this site sells will short and smoke at best or catch on fire at worst. I lucked out (I guess) because my shorted and melted the heck out the dome light fixture and didn't burn my ride to the ground. I replaced the whole dome light and put single LED bulb in there instead of CH panel after that. I think the problem was spring adapter connector but either way everything was toast and didn't trigger the fuse which tells me issue wasn't just short at posts but rather internal issue with LED Panel circuitry. Close call and I hope to prevent anyone from fire by removing or not ordering those dangerous panels.
There is literally nothing I would buy from that website.
If you want the panel replacements for the lights spend the money to get the Arc light led.
this is a copy of the arc light version.. changes are OP installed it wrong. Its very easy to mess up even when installing the arc light version.
i've installed 2 versions of the arc light version, its not a simple install. installed my meso ones, looks much nicer
Install seems pretty basic on the arc light, minus having to drill a couple small holes? I don’t have one but I’ve been considering getting one so now you’ve got me wondering how it’s not simple or easy to mess up?
Also, I don’t see the map lights on Meso’s site at all? Just the rear dome light for the 5th Gen
Archlights version is in stock. I can't say enough good things about it.
Same here. Super happy with my Arc Light rear hatch LED lights. Buy from the originator.
Icarus eXtreme LED Hatch Lights from ArcLightLEDs - 5th Gen 4Runner
[MENTION=196768]Agent_Outside[/MENTION]
"There is literally nothing I would buy from that website."
The T9 Head Unit is awesome from CTH.
Sorry to hear. I haven't had issues with their sequential turn signal mirror lights but I probably just jinxed myself.
Thanks for this
Why am I not surprised
Poorly developed and not tested properly Chinese junk that funds a Communist Army.
There were Chinese LED Helmet and Handlebar lights with lithium batteries for cyclists that were starting peoples houses on fire when they were being charged. I happened to buy a set and found out later. I kept them in a steel container outdoors when I was charging them and storing them.
Rich is correct. Beware of crappy LED retrofit automotive bulbs, home AC LED bulbs, and other products from manufacturers you’ve never heard of. They can fail early at best and cause fires in the worst case. It’s not fair to lump them all under the Chinese junk category (even though it seems that’s usually the case). Because almost everything we buy is made in China. But you have to do some research to find a reputable brand.
Another observation: I tried a high power LED dome light for the back seat area once. At night it was so bright it would temporarily blind the passengers when they got in the back seat. I went back to a lower power bulb after that.
With the arclight map lights and rear hatch upgrades you can pull the whole unit and make the install in the bench and simply snap the fixtures back in place.
The hard part is with the dome light, it doesn't come out or disconnect the way the other lights do. It's practically hardwired in with no disconnect so you have to install it in place on the ceiling. Makes it hard to reach and you get tired holding it up to make all the changes.
So remove a couple screws and pull the whole overhead console down and work on it at a bench. I put mine together at the kitchen table. This is like the people trying to use tape to remove the front dome light bouu look at instead of taking 1-2 minutes to drop the housing and remove the bulb sockets from above as intended.
