Cat Back Exhaust - Suggestions?
I am about to to this soon to mine (22re) so I will be following this thread. I want to go to possibly a 2.5 inch pipe for better performance and I might change the cat to a better flowing one as well being as they are a lot cheaper than they used to be. I did just change a friends cat back with a cheap system (about $110.00 Canadian) and I noticed that the pipe was smaller diameter than stock size. Keep that in mind.
I think the LC Engineering stainless cat-back set-up is the best on the market. While you're at it, install their ceramic coated, stainless header....I did.
Love to add a new header, in fact, I have to replace the ones that are on there now, since there is a leak....
Problem is, I have a V6.... Headers are EXPENSIVE!!!
The 22RE needs a bit of back pressure to run well and 2 1/2" has been proven to be too large. 2 1/4 is the recommended size for optimum performance.
Your'e right, that was a missprint on my part. I meant to put 2 1/4. More proof that you can't believe everything that you read on the internet.
I got the parts for a friends exhaust at a local jobber. They were cheap parts and not as good as we could have got but the price was right at the time.
I called to ask if the dynomax exhaust would fit my 88 and they could tell me nothing except someone has ordered that particular exhaust for an 89. Any help here? since 4wheel parts isn't.
I would order it through your closest store... That way if it does not fit, you don't have to eat it... Or pay shipping.
Where are you located?
Let us all know...
FYI - I did get an email from LC engineering about their product line.
they offer a few items:
3.0 V6 Headers - $799.95
Cat - $159.95
Pro Flow Exhaust - $ 389.95
I am confirming fitment on a 1st gen for the parts...
A little pricey, but we have little choice!!!
just do what i did. great perf, and great badass sound. about 2 inches after the cat, do a little slice and dice, and cut it off. if you have stock exhaust, cut the end tail pipe off (the part that goes to a 90 degree bend,) and clamp it on the cut off pipe. but a connector and some exo clamps, slip it all together, angle it a 90 out he side, and boom!! you are done. its loud when you really stomp on the gass, but good at low idle (great for sneaking home past curfew. it will save you from being grounded, or the dog house)
So, I called the second time after waiting for internet service to return and the guy at 4wheel parts told me they don't carry an exhaust for an 88 Toyota 4runner. He took my number, called me back, and told me he couldn't find anything. In essence, take it to the local shop and pay your 300 for their cheapo because it's your only option.
HELP!!!
this exhaust:
This recommended exhaust
is for an 89+
HELP!!! I need a cheap fix for an 88 4runner. I need a cat back package.
Sorry for repeating "this exhaust" and "this recommended exhaust". Sounds like I'm being a jerk but the label for the link didn't come out like I expected.
Okay, I'm close to half way through. I've got the old exhaust out. I started stripping a nut on the old direct fit cat so I opted to pull the drop pipe with catalytic converter so I could get a better angle on it. When I get it all back together I'll post the pieces I used, links, and price. RIght now I think I'm at about 180 for exhaust pipe, catalytic converter, muffler, tail pipe, and gaskets.
