i've replaced my secondary cats with a y-pipe. so they got nothing to steal plus i have a transmission skid that they'll have to work around if they were to try to steal something.
Will this pass CA smog? If so, I'm all for doing this
Yeah not sure if it'll pass the sniff test.
I've been meaning to go to a smog shop to pre-test - not even sure if they can pretest without taking my info?
i'm sure you can find a shop or a buddy knows a shop that'll "pass" it for you for a little extra lol.
Not sure if the changes had become state-wide yet or not but even before the pandemic, smog checks that I had on my cars did not have sniff test anymore. It was only OBDII scan and visual test. IIRC, sniff test was only for car that does not have OBDII port, which are those made before 1995.
There's still ways to "pass" it but it's not as easy as how it used to be.
I see Talon's product, but it only says compatible to 2019 model. I have a 2022 TRD Offroad with KDSS. Does anyone have experience/can confirm if this is compatible with my configuration or have experience with any other products that do?
Thanks in advance.
I just installed it and it fit fine with my RCI front steel skid plate. Two things I don’t like about the Talon’s product:
1. The side wings/plates are bolted on as part of the install. I put the vertical wings on, but left the horizontal side plates off. It looks like the cross member bars will prevent you from removing the cats even if you could jam a sawzall in there.
2. All the fasteners are Allen/hex rounded heads. Wtf. Now I need one more wrench when working on this thing. Lol. They should have just used longer grade 8 versions of the existing bolts.
Price wasn’t horrible and it fits good. It will provide good rock protection as well. Peace of mind at least regarding that topic.
I left the triangles off. The smaller rectangle pieces bolt vertically up the sides of the main skid.Which of the plates shown below are the ones you left off? I see where the triangular shaped versions go, but not the smaller plates...
I installed the Millercat product on my 2022. Followed instructions exactly, but had a nasty rattle on the left side against the cat, so I had to modify it to prevent rattle. This isn’t something that should be necessary on a product this expensive. I even opted for the more extra expensive stainless steel version, but I find it flimsy and cheap feeling.
Wouldn’t buy from Millercat again.
