cellar
Problem is it is working when I think it shouldn't. :wow: I'm re-installing my CB on my current truck. It worked prefectly well in when I had it installed in the other truck. Once, the ground connection came loose and it didn't work. Hooking the ground wire back up fixed the problem.
The CB is a cheap Radio Shack unit I got for next to nothing.
Now what really has me confused, is that hooking up +12v power to the CB with no GND connection causes the CB to seemingly work fine! (I say seemingly because it turns on and static is heard. I'd have to drive to the truck stop to get any reception to test.)
I have the power running in from a new aux fuse box I installed with some equally new Hella lights. Originally, I had the CB +12v connected with the power feed to the light switches. Figuring that the CB might be shorting to ground via the switches, I ran the CB power off it's own fused terminal and encountered the same thing.:redbrick:
There seems to be no other electrical connection to the CB other than +12v power . So how is it turning on???? Must I be shorting to ground somewhere?
