SilverBullet01
Senior Member
ok, so I got myself a Cobra 19DXIV and mounted it in the ashtray spot like most other 3rd gen guys. Using a 4 foot adjustable firestik, 18 foot coax with a fire ring, and im having some swr issues. the smallest section of coax that the local radioshack had was 10 foot to use as a jumper to my swr meter that I picked up from frys. I taped into the power for one of the aux power outlets in the dash.
so my issue is every time I set the meter to tune it, as soon as I switch it to REF it gives me an off the chart high reading. I adjust the antenna and still nothing changes with the readings. Im using a Drifter33 made rear liftgate mount. and I'm grounding it by running a ring connector with wire up into the rig and connecting it at the ground point of the rear drivers side tail light.
any ideas what could be wrong?
