CBI front skid?
I am considering replacing the factory front skid plate for a CBI off road. My factor skid has been fine and is still in great condition. The main reason Im considering CBI is because it looks like you can change the oil without having to remove the entire skid. For those that have it is it worth it? Does it make changing your own oil easier?
hmmm thats a hard one to say...paying a few hundred more to make it easier...I will say it made my life A LOT easier lol. There are also other skid options that could be cheaper. Can't recall but CBI shipping used to be pretty darn expensive. Most aftermarket skids have an access port for the filter.
CBI shipping to AZ was I think $325 when I checked a few weeks ago.
Most skids other than the TRD allow you to change the oil with out full removal. I went with CBI
I'll agree with that, for whatever reason CBI shipping rates are ridiculous. The best you can do is buy a CBI product through a reseller/retailer that will charge significantly less for shipping or even for free.
[MENTION=201265]TheJokingExplorer[/MENTION] you should contact running4tacos shop to see if they can get you a CBI skid locally and that way you can avoid their shipping rates
I'll agree with that, for whatever reason CBI shipping rates are ridiculous. The best you can do is buy a CBI product through a reseller that will charge significantly less for shipping or even for free.
I just saw that SDHQ has them and their down the road from me in Gilbert AZ.
Sounds like you found a good deal if you can drive over and pick it up locally. As others have said already -- most aftermarket skids make it easy to do oil changes. CBI, RCI, LFD, C4 and 4x Innovations to name a few. Personally, I'll probably end up with a set from LDF because of the $75 shipping. I also like that there is a hole for the engine oil drain plug and a plate for the oil filter instead of having two plates to remove.
