cdrewferd's build thread
cdrewferd
So I've had this 99 4Runner for about 8 years or so. It was my wife's daily driver until about 2 years ago when we got her a Sienna. I just recently was able to start building it. Here's some specs on the base 4Runner:
SR5
V6
Automatic
Rear Locker
255k
First thing I did was buy a used OME lift off craigslist. Thought it was a good deal at the time, more on that later. I then started gathering parts to go trough the whole front end to make it all like new. Here's a list of the parts I picked up.
OEM Upper and Lower ball joints -new OEM bolts or the lowers too
OEM Inner and Outer tie rods - new boots as well
OEM front wheel bearings - planned on doing both sides
OEM Upper control arm bushings
Safari Ltd steering rack
Ok, so here's a few pics.
Started with this:
Swapped rims and 231mm rotors and calipers from my moms Sequoia that was being totaled:
Last weekend I started all the work to redo the whole front end and put on the 3" OME lift.
Didn't take any pics of everything torn apart. Was just busy trying to get as much done as I could while I had my brothers help.
Got the steering rack torn out and set next to the new one:
The old inner tie rods were limper than an 80yr old man wit severe ED:
Got the steering rack in and the lines hooked back up. The lines were the worst part. Then I finished up the drivers side as much as I could:
Once I had this I diverted my attention and knocked out the back. Didn't take any pics, but it's OME Shocks and 891 coils.
Then I prepped my newest purchase for install:
Got these Light Racing upper control arms from a member here. They look awesome and I can' wait to use them more.
I had to finish up the drivers side and put on the tire just to get an idea of what it was going to look like:
As you can see it was very tall in the front. Was hoping that with weight on the front it would settle down a bit. I had to take a break at this point as I needed to have the drivers rear and passenger front wheel bearings replaced. While I waited, I installed my 1” RB body lift with steering shaft extension.
Once I got the bearings replaced I got everything reassembled and got it ready to take to get an alignment. This didn’t work too well. The front was extremely stiff and I could hear the CV’s clinking at the angle they were being forced to. I turned around, having only driven maybe a mile. I got home and stuck a jack under one control arm and jacked it up to its max 20”. Neither the drivers or passenger sides flexed. I was thinking that since it was a used lift, maybe the shock shafts were frozen on the bodies. I sprayed each with a lot of WD-40, but they still wouldn’t move. So I pulled the front lift and headed to Toytec. There I worked with [MENTION=9139]steezemcqueen[/MENTION] and he was a great help. We figured that the coils had to be OME 882 which are rated for something like 450+lbs on the front end. So, it was time for new coils. Decided on the 881 on the shocks that I had. Once they got the first one taken apart they noticed that the top hats had been elongated and wouldn’t sit right on the shocks. OK, new top hats. Then they took the second ones apart and found that while it’s top hat was also elongated, the shock shaft was also about half warn through. This didn’t make me very happy.
Luckily Dylan was very patient with me and spent the time talking me through my different options. I could go with 5100’s and some 881’s then upgrade to the 883’s once I get my front bumper and winch. This wasn’t that appealing as I didn’t want to have to keep taking things off. This left me with one option that the wife gave the green light to.
These coil overs are awesome. They have already been very nice as I’ve been able to start to dial in my suspension height. This is how it was sitting after an alignment.
Well, partial alignment. Going to go to Toyota on Monday as Firestone just made excuses for why they couldn’t get it spot on.
This is where I’m currently at. Going to be doing the basis for my sliders this coming weekend with my brother. He’s also going to be helping me to do front and rear bumpers.
lookin good! this ones gonna be sweet!
never go to firestone, they charged me $170 just for diagnosing a cel running lean code, wanted $650 to fix it.... ya right, they are just as bad as les scwab, bunch of criminals
Thanks. I'm trying to figure a way to get my wife to let me buy some 285/75 r17 Toyo MTs. I want those as they are narrower than a 12.50 and only .7" shorter than the 35. They will also fit on my 17x7.5 rims.
Getting an alignement today. Funny, after Firestone made nothing but excuses I went home and worked on the front for about 30 minutes. Drives better after I redid their job than when they got done. I didn't even have any fancy equipment, just did everything by eye. Guess I won't be going back there any more.
Looks good Drew!
Sorry about all the BS with the OME stuff. Hopefully I knocked enough off the coilovers to make the OME's not a total loss!
Looks good Drew!
Thanks for knocking some off, that was very nice of you. These are probably a little better than the OME stuff anyway, lol.
Need to start trimming. Those are 35x12.50 r17s. Used, but for $150 they were too good to pass up.
20130626_181359_zpsffb02a10.jpg~original
20130626_181405_zps9abe672d.jpg~original
20130626_181413_zps5e151f45.jpg~original
20130626_181424_zps2deeef8e.jpg~original
Well, not going to do the 35s as they are just too wide. I do have tires on order though, and should have them on by the end of the week. Should have my sliders done on the 19th, so I'll post pics once my brother gets them welded on. Then the first shakedown run is going to be on the 27th. Hoping to hit Chinamans near Buena Vista.
Have to say, if you're looking for tires go to Tread Depot.com. They have amazing prices. The local Discount Tire price matched them and I'm getting a great deal on new shoes.
Hell yea man, great start to your build! Looking great.
Thanks.
So I needed to install some spacers before I get my new tires. Got 1.5" All Pro spacers as they were a great deal on the forum.
Before:
Spacers just installed:
After:
Gotta love the cross hatch on OEM 231mm Tundra rotors:
Tires will be on tonight. Will post pics when they get mounted.
Looks good! I thought I would stop by and take some measurements after you got your tires mounted, but I didn't realize you have aftermarket UCAs... might be a little tricky to get a good idea of how much space is actually back there.
Your wagon looks great though!
You can still stop by and take a look. They said they would be in today, but not sure as I haven't gotten the call yet. I'm going to take my sawsall with me so I can clearance the front bumper enough to turn the wheels and make it home. :rofl:
Due to a mixup with shipping, they only have 3 tires right now. So I had them mount one on my spare rim so I could start trimming. Tires are 285/75r17 Toyo MTs.
20130713_150318_zps7325e96e.jpg~original
20130713_150346_zps0c01714f.jpg~original
20130713_150527_zps28858e17.jpg~original
Can't wait to get the 4 mounted on Wednesday.
Got a little trimming done. Didn't get any pics of the front. Main thing I had to trim there, just to be able to turn, was the plastic valance. On the rear I just had to remove the rear mud flaps. Will do more trimming once I get all the tires mounted and I can flex it out. Will do the pinchweld/tubbing this weekend.
I am going to have Toyota redo the alignment. When the tech did it, he pulled the lower arms all the way in. When I turn the front wheel, the back of the tire rubs on the frame. Going to have them push the cams the other way to push the arm out and then I'll clear at full lock. Not sure about when flexed though.
Well Discount has really dropped the ball on this one. The 2 remaining tires were supposed to be here yesterday. I called and found out that they had been shipped to CALIFORNIA instead!!!!!!!!!!!!!!!!!!! This really sucks. I'm headed to my brothers this weekend to do all the clearancing and put my sliders on. Really wanted the tires so I didn't have to move 1 tire around to make sure everything is trimmed right. They shipped 2 more tires from Amarillo today, but they didn't even overnight them, just regular UPS ground. So frustrated but not really sure what I can do about it.
2001ATL
