CEL, VSC TRAC, VSC OFF, Slip Indicator Lights are On
advracer
So check this out guys...
I attempted my first car maintenance by changing all 6 spark plugs (took 3 hours). I started out with the driver side first and unhook 3 cables (2 hoses and 1 electrical thing). After replacing all 3 spark plug, I was stoke that i started the car and forgot all about to put back those 3 cables. Well, i powered the car off, and finished the other 3 spark plugs. After i was done, i made sure that everything was in place and that everything was put together. So i started the car and those lights came on: check engine light, the vsc trac, vsc off, and the slip indicator light. I drove the car around the block thinking it would go away but they didn't. I know i'll have to take it to the dealer. so my question is, how much do you think this will cost me to get it fixed?
thanks in advance!
Unhook the negative terminal on your battery and leave it off for 10mins. Then put it back and see if that makes your problem go away. This will reset the computer and should get rid of the lights if there isn't still a problem somewhere.
Also, if it doesn't get rid of the lights, take your truck to autozone (or equivalent) and have them read the codes to see what the problem is. They will do this for free where as the dealer will charge for this service.
TRDCal---removed the negative battery, waited 10 min, and started the car....It WORKED!!!!
Too cool!!!! thank you!!!
seltzernator
