Center Stack Stack Clips
batmant
I'm not sure what to call them other than "clips". If you've ever had to remove the trim around your center stack (radio, hvac, etc.), you have these metal clips that secure to the plastic and lock the pieces into place.
I recently bought a 2002 and did some maintenance (bulbs, aux input, etc.) and each time I've removed these pieces I've either lost a clip, broke a clip, or had to re-secure a clip. They look like the kind of clips that are initially secured via needle nose pliers.
Unfortunately I don't know what these clips are called or where I can find a bunch of news one to put on so that my trim pieces fit more securely. Any help is much appreciated. Next time I have the pieces out I'll take a picture but I suspect most people know what I'm talking about.
just all up your local dealer, they probably have a few in stock, as Toyota uses them for a lot of different models. Your armrest on the door is also held on with the same clip.
tuṣṭāva
