Why does the shop want to pull the shock and out it into the wall compressor ?
The metal CF spacer bolts to the metal plated with the 3 studs where the shock top goes through. Si its basically a metal on metal think. What benefits does he have in pulling Xreas off and putting it on the wall compressor . The spring just need to be pulled down and the spacer slid in correct and it will be metal on metal and then you put the rubber bushing back in and decompress the spring , correct ??????
