Simple question. Does it turn all the time or just when the 4 wheel drive is engaged? Or, when its put into low 4wheel drive?
. . . Is there really a Chain in there?
Sure is — in both versions.
I'm not sure if the case rotates in the Limited and Trail in normal driving.
Thanks for the answer. I had heard nearly all light four wheel drives use the chain system because it is so much quieter than gear on gear. I could not imagine it turning all the time but then some engines use a timing chain that runs all the time. As sort of a gear head I still don't understand why they suggest running the four wheel drive once a month or so. Its not like it will rust or something but then it might just keep the linkage freed up.
What does it mean by the t-case is being "locked" when you switch the Limited into 4H or 4L? Its engaging something that normally isn't. But I guess you're right that something has to be moving in there with AWD.
There is the other reason to use a chain the transfer case - it's the weakest link, and when you overstress the 4WD linkage by, say engaging 4H on a dry road and doing a bunch of turns, the chain will fail. Ostensibly the system is designed correctly and will leave you with RWD only when this happens. On gear-driven transfer cases, the actual transfer case housing will fail, and you'll lose all drive, and get to call a tow truck.
Shouldn't the u-joints in the system be the weakest links as they are the easiest and cheapest components to replace?
Sorry, I'm new and can't make a new post. I have a 2012 limited with the full time 4wd transfer case. Looks like the fluid got low as I had to put about 400ml in to top it off. Apparently that caused pretty excessive wear on the chain. I can move it quite large amount with a screwdriver through the fill hole. I think it's so bad it's jumping teeth. Apparently this is pretty rare as several searches turned up nothing. Rock Auto doesn't even carry the parts. Has anyone done this? I've done it on an old XJ Cherokee (NP231), but I'm sure this one is significantly more complicated. Any tips would be appreciated.
I've rebuilt transfer cases. The chain is always moving, but it is under load only when it is engaged in 4Hi and 4Lo.
AWD transfer cases it's the same, but the AWD introduces a clutch or a torsen differential that distributes power, so there is designed slippage.
This is a little too long but good info…
Transfer Case Operation - YouTube
