Changed fuel filter but now strong gas smell
calnhob
Member
So I changed the fuel filter this past weekend and now there's a strong gas smell when starting the car, last about a minute. I checked around the filter thinking there was a leak but no leaks found. No CEL and everything runs fine.
I'm wondering if the ECU needs to adjust the air/fuel mixture.
Anyone else have similar issues after changing the filter?
I would say get under there and take a good long look at those filter threads. I thought mine was seated nice, clean, and tight. I noticed a small leak. Like, it was taking a long time for a drop to form, but it WAS leaking. Upon removal and close inspection, I found a small, like pretty freakin small piece of debris had gotten between the threads as I tried to speed up the installation and avoid excessive fuel loss. This prevented the fuel filter from properly seating on one side. I removed filter, cleaned up the threads on both ends and tightened it back down. That fixed mine. But you shouldn't be smelling gas.
Years back I bought a Fram filter that didn't seat properly at the union. Returned it for another, which had the same problem. Returned second Fram filter and bought a Bosch filter that worked perfectly. :whoo:
Pull out the EFI in your circuit box for ~20 minutes to reset your computer. Though I think your problem is more likely a small undetected leak at your filter. I recently swapped my filter and I had to go at the threads with a wire brush to stop it from leaking.
Fuel lines were notoriously over torqued from factory deforming the flare on the line. If it is wet at all you may get away with tightening it a little more.
Have you checked the regulator and rail damper ?
It was a PITA to get the line existing the filter to seat properly so maybe that's the leak. Will check again when I get home.
And it was a FRAM filter and I was rushing a little cause the gas smell was so strong plus GOT was starting. :dizzy:
Not sure where the regulator and rail damper are located, I'll have to YTube it.
