Changed spark plugs... One was covered in wet oil...
1clean4runner
...Wet oil, as opposed to black, charred, burnt-looking.
So I changed my spark plugs today on my 2007 v6 @ 67000 miles. Last time I changed them was around 30000 miles.
I replaced the factory ones with Autolite plugs @ the 30000 mark (not the best... I know. Noob behavior). This time I changed them with Denso plugs.
EDIT: Not sure this is relevant, but I recently noticed the coolant level is low; as in I need to refill it within a week. See my post further down.
Here is what 5 of the 6 plugs looked like...
EDIT: The first one quoted by scottji is different; I tried to get a better picture here.
IMG_0996.jpg~original
All completely dry. Anything that may appear wet in this picture is simply "charred".
Here is what 1 of the 6 plugs looked like...
IMG_0992.jpg~original
Covered in oil. From the threads of the spark plug, to the nut-part where the socket wrench hangs onto.
Looking at the front of the car, it's the cylinder on the right, furthest back, closest to the driver's seat.
Not sure what's going on here. Never had any check engine lights. Never had a loss of power (that I know of). Engine runs smooth as butter, aside from the infamous ticking and shaft thunk every now and then. I don't recall having oil like this on the spark plug when I last changed them. I torqued them all 13-15 ft lbs.
Any thoughts of what is going on? Did I simply not tighten that plug enough last time? Anything problematic? Thanks!
IMG_0991.jpg~original
All completely dry.
Covered in oil.
Full disclosure -- I have NO idea what this means on a Toyota 4Runner. However, oil in the spark plug hole is a fairly common problem on BMWs that I am familiar with. It signals a bad valve cover gasket. The gaskets on the BMWs have one part that seals the edge of the valve cover to the rest of the engine, and a series of rings that sit around the spark plug holes, and seal off the holes from the valve cover gasket. When the gasket material on those interior holes get old and brittle, oil will begin leaking into the spark plug hole. You want to fix this because it can cause problems with your ignition coils.
Check some parts websites for a valve cover gasket for your car and see if it comes with a series of three little rings that sit in the middle. If so, my vote is to replace the VCG and see if that helps.
I think that is the #6 cylinder where the V6's have head gasket issues.
Crap. Sounds like I need to do some research then. I really was hoping it was something dumb and inexpensive.
It's not even my truck and I hope you're wrong......
I think you're right though from everything I've read.
To think how proper I keep this thing... for something like this to happen...
I'm trying not to freak out.
Now that I think about it... I recently noticed the pink coolant is near the "low level" line... haven't touched it or refilled it since I got it though (@18000 miles).
Yep. Oil in plug. Low coolant level. Those two together are a pretty good indicator of head gasket issue. The low coolant level is caused by the coolant slowly seeping into the cylinder.
That sucks. Good karma to you. Have it checked out.
This prompted me to look around a little, and yes, there are at least 3-4 cases of head gasket issues. Found 1 that was a cracked head - but there were a lot of issues like rough idle, CEL, etc..
Hopefully it's "just" a gasket - if anything.
That really sucks.
Keep us up to date - and it's something else to check for when we replace the plugs.
This prompted me to look around a little, and yes, there are at least 3-4 cases of head gasket issues. Found 1 that was a cracked head.
That really sucks.
There are about double that documented on the internet.
Yeah I knew the coolant level going down isn't a good thing, however I didn't know what oil in/on the spark plug meant.
I'm going to try to dig up as much as I can find now. I'll keep this updated. Maybe I'll take out the new plug again after I've driven a couple hundred miles and see what it looks like?
I don't know. Any suggestions as to what pictures that I could take of the engine that might possibly help out?
So, Changing the plug isn't going to help. I know it would sure be nice to change the plug and that it would magically be better.
Coolant literally destroys an engine. The sooner you get it looked at the better. Don't hold off, hoping it will get better.
That's not what I meant. I just changed the plugs right before posting this thread. I meant that I will just pull that one new plug (in cylinder #6 I guess?) and check to see if its covered in oil again after a hundred miles, versus the 37,000 miles it was since last time.
Yeah it's sounding like this is going to be taken to the pro's.
Sounds like a valve cover gasket to me....not a head gasket at all.
You can replace the valve cover gaskets yourslef if you are mechanically inclined. Might aswell install a supercharger while you have everything apart :D
I did an engine swap and custom turbo kit on my civic about 8 years ago, and I installed the daystar on the 4runner...
Don't tempt me with a supercharger :hungry: Haha
What would the head gasket symptoms be? I came across this thread which got me a bit concerned... http://www.toyota-4runner.org/4th-gen-t4rs/51415-engine-goner-warped-head-long-block.html
From what i've read about it that cylinder starts missing and it starts throwing lights...usually a lot of coolant goes missing too.
Some mechanics have a H/C (hydrocarbon) sniffer. They can stick a probe in the radiator and tell whether the head gasket is leaking. Another giveaway is in the exhaust. If you have a leaky head gasket, the exhaust fumes will be wet. It will be foggy and will not go away. Is coolant blowing out of the overflow tank? are there any leaks around the T-stat?
That sounds exactly the same with the back, driver-side plug being oily. Do you know how involved it is to replace that valve cover gasket they mentioned?
I'm still not sure why my coolant would be low though.
Your car will burn a little coolant normally, with pressure release valves and whatnot. My guess is that if you take your skid plate off, you'll see a white residue on the underside of it from coolant dripping down there. That's normal, just keep an eye on it and keep it at the appropriate level. If you're losing a lot, take it to a mechanic. Could just be a radiator hose, water pump, bad seal on a tstat, but best to be safe.
A 5-minute search found all sorts of suppliers for VCGs for the 4.0L 4Runner engine, right around $20 per side. I'd search around for valve cover gasket DIYs online. Barring that, first thing I'd do is pull the plastic engine cover off and look around. You'll probably have to move some brackets, wires, etc., but you should see the valve cover bolts. I haven't done it on my 4Runner, but for my BMW it was easy -- undo the valve cover bolts, carefully pull the valve cover off (yours is likely plastic, so take care not to crack it when you're pulling it -- a putty knife works well to loosen it at the edges). Clean it with some carb cleaner and set it aside to dry. Carefully scrape all the old pieces of the old VCG off, replace it with the new VCG (the new one may press into a ridge on the valve cover). You'll note how brittle the old VCG feels compared to the new one. Use hylomar or sensor-safe hi-temp RTV on weak or uneven areas (corners, round areas, etc.), and seal it back up to manufacturer's torque specs. I can't imagine it's that different for your car. I think you'll figure it out once you're in there. You can probably get it done in an hour or so.
