Changed the Plugs
AE1M
Member
I have a 2008 V6, this vehicle really is one of the easier new vehicles I've had to change the plugs. If you're considering it but worried, it's really easy.
I suggest getting a set of locking socket extensions, I ordered these.
The only problem was the plug closest to the firewall on the driver's side, a few obvious things to get out of the way.
You'll need a 10mm 6pt socket to take the coil packs off, and a 12mm 6pt socket to remove a bracket to get to the plug closest to the firewall on the driver's side.
I used Deno SK20HR11 Iridium Long Life Spark Plugs, the gap was fine from the factory, pretty close to .042-.043.
Suggest having a nice portable light source you can clamp in to things to see the back 2 plugs and connectors on the driver's side.
The coil packs disconnect with a tiny pressure from a small flat screwdriver on the little tab, then pull them off.
I didnt use any anti-sieze goop at all, the factory ones with 31K came off very nicely. Torqued the plugs to 13ft-lbs.
Bob
Was there a reason that you changed plugs already? What was the condition of the original plugs?
Just curious,
~Doozi
Just curious,
~Doozi
Just doing the regularly schedule maintenance per the owner's manual at 30K for the emissions warranty. 3 of the plugs removed were NGK and 3 were Densos from the factory and they looked in good shape.
I should be set for 50K miles with these Iridiums.
Bob
Just curious,
~Doozi
Factory recommended service schedule.
I done mine at 30k and they looked fine as well. Probably go another 10-15k. I noticed it idles a bit smoother with the new plugs. I used all Densos this time around.
Exactly the same. Cheap insurance to keep a $35K vehicle running good. Not sure why they believe these plugs need changing at 30K though, mine looked very good also, could have gone at least another 10K+.
Also put in the Denso Iridiums.
I also use a top tier gasoline though and Techron treatment every 15K miles also in all my vehicles (2003 vette, 2007 Harley Dyna, and the 2008 4R)
Bob
