westwind77
A few hundred yards from my street I picked up a broken/worn bolt on my rear drivers side tire, one end was worn down to an 'ice pick' point, and the other still had the nut on the end, about 3" in length. Parked in driveway, pulled it out, figured now would be a great time to learn the tricks of changing the tire on the new 4R.
Pulled the jack out with all the related hardware/tools. Here is were I ran into an issue that could be a PROBLEM for others who run into this on the road. The jack handle extensions have Phillips Head bolts on the ends that are used to connect/tighten them to each other. The PROBLEM is that these bolts were in fully inserted into the pieces, therefore there was NO WAY to connect the handles together without 1st unscrewing them. I was home so just picked one up and continued but if you are on the road and do NOT have one with you, I have a feeling you might be there a while waiting for AAA! These were inserted before they painted the pieces because I had to break the paint bond when I unscrewed them.
I figured I would post this so people can break these bolts free now so when they need to use the jack they actually can!
Ultimately I 'cheated' and used my floor jack because it is just so much easier but I wanted to make sure I knew all the steps and placement for when I am not near the floor jack.
I am curious to know if anyone else has run into this or to see if theirs are the same way?
