Changing brake lines with lift
Brake Line Length
  • Kept Stock Brake Lines
    Votes: 20 87.0%
  • Upgraded to Extended Brake Lines
    Votes: 3 13.0%
  • Total voters
    23
Desid
For everyone running 2-3" lift did you guys use extended brake lines? Im not planning on rock crawling or super crazy off roading. I couldnt seem to find anything of the forum about it.
Unless you’re running long/extended travel, or have over 3” of rear lift, you don’t need to extended the factory hoses. Probably why there’s so few posts.
Makes sense. Just didn’t wanna destroy mine
Yea, it’s a smart thing to consider. Some vehicles require them absolutely, I know my JK did with 3” coils.
Up front, be cautious of the abs line, damage there from clumsy installs is not uncommon. In the rear there is a bracket on the frame that can be disconnected to give you some more breathing room when installing coils. It’ll be evident once you get under there.
delislerebecca
