4Runner168
This has happened to me like three times in the past 18 months so I am not sure if it's normal or not so I wanted to ask around and see if anyone else has experience this before.
The other day I was driving in 4HI in order to lube the system since I have not used it in a over 45 days, I made a full stop to drop off some groceries (engine still running), once I was done I then switched it back to 2WD and proceeded to driveoff and make a turn while the transmission light was still blinking (I am referring to that icon with the x in between the four wheels in the dash that blinks when switching between 2WD and 4HI/4LO). When I made the turn the vehicle felt that it was "stuck", the vehicle barely moved and it felt like something was holding it back. I tried slightly pressing on the gas pedal but it still barely moved so I eased off, I then decided to turn the front wheels to a straight/forward position and the issue corrected itself after a clunk noise.
Is there something wrong with my transmission that I should be concerned about? Has anyone else had a similar issue with this?
