Blanco
My 11 year old daughter and I use our 4Runner a lot for camping trips and take our totally budget fishing gear with us when we do. We're far from pro-anglers but we both love it nonetheless! Usually the back of the truck and the roof basket is loaded down with gear so I thought about buying a Flambeau bazooka case for the rack but since our cheapo rods disassemble in half, I came up with a much cheaper idea.
4' of ABS tubing from Home Depot $12.00 (CAD)
2 end caps $6.00 (CAD)
I cut down the tube to the size required for the rods and drilled two small holes on either side of the cap end, a bit of silicone sealer around the edge and attached with two small screws for good measure.
Drilled two holes and attached two old Thule bolts I had kicking around from an old rack (and a little more silicone sealant).
Rods slide in like so...
Now the only things I have to do now is fab up two brackets to attach to my roof basket and figure out a way to attach the other end cap for easy removal, though to be honest it goes on tight and seals well, yet pops off easily when required so may just leave as is.
Here is what it will look like (no brackets yet) but you get the idea.
Heading camping for one last blast next month so will try it out then!
