Cheap maintenance for these cars?
biskit
This week I took our 4Runner in for 15k mile service. According to Toyota
If a warranty claim needed to be filed they could claim 5 miles of towing means 'used for towing' as a way to hassle you. At 5000 miles worth of towing there's no doubt you should maintain it to the towing standard.
I have thought about this and edited this: I would change the axle and t-case at 15k. It still has the original fluid in the axles and t-case. During breakin the oil gets hotter than normal and some extra metal shavings. This is especially true for you as you work your T4R by towing. Get the beat up, metal flaked oil out by changing it at 15k. After the initial change a 15k change should be done as long as you keep towing. And yes, I would do my t-case at 15k then as prescribed.
The transmission should be done at 60k and that interval is probably just fine.
:cheers:
CJ3...
I think I'm missing something...
You said "The towing standard says 30k and that should be plenty good on the T4R."
Uhm... the guide says to do the "extra" stuff when "Driving while towing" at 15 thousand miles AND 30 k.
I B Confused!
As you should be. I've edited my reply to actually comment/answer your question instead of babbling like an idiot.:bash: Part of that was looking at the maint schedule; my answer makes some sense now:D
Why Thanky, Chris!
Something else I noticed, too...
IF I'm reading the guide krektly, I don't need to do timing belt til 90k, and Spark plugs until 120k?
Just seems so... long to do this stuff...
Or... maybe not... Our Explorer Sport didn't require plugs til 100k (did 'em at 85k anyway), and it doesn't have a belt...
Idunno... it just seems like the 4Runner doesn't need much to maintain it correctly.
Don't get me wrong... I ain't complaining... I'm just not used to it.
biskit said:
Why Thanky, Chris!
The timing belt interval is fine at 90k. There's also an age stipulation so if somehow the T4R gets to be 9 years old??? (108 months) it should be changed even if you haven't hit 90k miles.
As far as the plugs are concerned I would do them at 4-5 years and under 80k miles. The plugs will work fine and the motor will run well to 120k. I get nervous about leaving them in too long due to potentially getting corroded and stuck. That's just an IMHO, many may just let it go to 120k.
:cheers:
The transmission should be done at 60k and that interval is probably just fine.[/color]
:cheers: [/B]
Chris, doesn't the Runner have worldclass life long fluid? Do you still think it should be changed at such?
I think the non-towing interval (never!:confused: ) specified by Toyota is very ambitious and quite frankly BS.:FOS: The Towing interval that Toyota specifies is still ambitious but acceptable to me. The fact the new T4Rs have the WS fluid is why I'd even consider 60k. (If I never towed & never 4wheeled I would still change mine by 75k.)
IMHO: With 'old school' Dexron and no oversized aftermarket cooler I would change the fluid at 20k towing and 30-40k non-towing. As I understand the WS fluid it is conceptually like using Mobil 1 ATF in place of regular Dexron hence the longer 'acceptable' interval. (Don't read into that... Mobil 1 is NOT an acceptable alternative to WS fluid. The viscosity is different among other things.)
Look at this and scroll down to the "Additional Maintenance Items for Special Operating Conditions: Driving While Towing": http://smg.toyotapartsandservice.com/guides.php?v=1&y=2007&int_id=12
:cheers:
AndiGarage
