kingofavondale
Ok, so I did the first oil change on my 2000 4Runner since I got the car ~2500 miles ago (did it early because I got it from the dealer and I have not idea what crap oil they put in there). Discovered the round-about way that you have to remove the skid plate do change the filter (should've read the boards, would've been easier if I had known). But anyways . . . that is irrelevant.
I used Mobil 1 5w-30 and a K&N oil filter. My manual says that with filter, the oil capacity is 5.5 quarts. I put in 6 and it almost touches the second dot on the dipstick (is this normal? Is the manual wrong?). Oh yeah, I'll also admit to spilling oil all below the filter when I took it off (saw no way to prevent it, suggestions anyone?).
So now I go to drive it to work, and about 10 miles from my house I notice that the Check Engine light is on. Well, when I get to work (Kragen Auto Parts), I "borrow" one of the OBD2 readers, take it out to my car, and pull off the code. The code is P0420. The reader says that I have 'low catalytic pressure' and when I look up the code in one of our books, it also lists that there is a misfire in cylinder one.
So, wtf? Did I do this to my truck when I changed the oil? I don't see how I could've, but I also don't know the truck as well as some of you. What's going on? Has anyone else had this happen to them? Any help is appreciated. I'm taking it in to the dealer (still have a warranty) on friday morning.
