Check engine light Vsc trac Vsc trac off
deadmaggot6
Heres the rundown. 02 4runner limited. 80000 miles. I recently replacedd front brake pads. on the driver side i took the 4 14mm bolts out and the caliper split it, there for leaking brake fluid. Retorqued down the caliper and replaced brakes the correct way. did the other side. Then started up the 4runner. and got these lights. Bled brakes on both sides numerous times. The check engine lights go off for a while then come back. Anybody have any ideas?:confused:
