check engine, vsc, and trac light on ?
kholstad08
Did the andy mod a few weeks ago havent had anyprobs though, was driving on the reeway yesterday and check engine, vsc, and trac light came on..... ANY IDEAS?
"Andy mod" is to disable VSC/TRAC?
I guess I'd suggest undoing it and see if the lights reset. Have you hooked up a scanner to your OBD port to see what code it's throwing? I'd do that first, probably.
It threw a code. I have same switch and most of the time I can turn it on and off with no problem but every once and a while it throws a code and I have to use the scan gauge to clear the code to get the lights off.
cool, thanks for the input guys.. was kinda think i needed to plug it in and clear but wanted a scond opion,
thanks again
