Chirpping sound in back, right, rear...
SLOToY
This problem only happens when my foot is OFF the gas. It is a very audible chirpping sound. Like when I am coasting to a right hand turn or a stop sign... I give it some gas, and it goes away. I pull out of the turn or stop sign, give it some gas, then let off the gas and the damn chirpping sound is there again! Any ideas???
1997 LTD 152,000 Locking Diff/ Tow Package/Power Everything
:( Uh oh sounds like a problem I had with my rear axle seals. If your lucky it might just be the plate on one of the drums. Any work done recently?
Try to narrow down the occurrence a little more. With my problem I figured out that it only happened when it was cold out and, like yours, only when the vehicle was in motion with no throttle given. Does it chirp when you turn only to the right (or left)? Does it vary depending on the amount of throttle? Find an open parking lot and take good notes as you experiment if you need to.
