Christmas lights/rear power outlet
Neauxla
So I strung some Christmas lights around my Camelback roof rack and was all excited until I put the car in drive and the rear outlet turned off. Is there a way around this issue?
I use two strands of LEDs and have been since I bought my 4Runner. No issues and all I have to do is make sure my wife doesn't add more strands than the watt can handle
Shotgun Shell Lights
Went redneck on mine.
I did LED out the sunroof last year.
I found out the plastic covering on the lights could scratch the paint, so I put a piece of cardboard near where I was working.
It was sort of a PITA I would knock into the cord. It went from the rear center of the sunroof down to the console.
Curious how you run power out the back. I was worried I would pinch the cord. If the window is even the bit cracked the rear defogger wont go on.
As others have stated, buy a string of solar powered LED lights! Once you charge it up, string it wherever desired, the sun will re-charge and as the sky darkens, voila...Christmas Lights!
For example, I shot this 5:45am (45 minutes before morning twilight). This was shot at Sprague Lake in Rocky Mountain National Park. Nearest power outlet would be my 4Runner about 300 yards away (at best).
So is the read window a crack open for the cord?
Nope .. ran out in between the weather stripping (be careful opening and closing the rear door because of it though) and up and out in between the backdoor and the exterior body. There is a little gap in between the door and the car to allow it to float in between and out.
Hope that all makes sense, ha.
I haven't had time to do it this year, but here is last years getup.
Reviving an ancient one here.
How did you guys route the cord through the hatch to the roof rack? Any issues with the plug on the roof? I was figuring on wrapping the cord plug between the extension and strand in a ziploc and tape.
delislerebecca
