Cigarette outlet in storage compartment
Red3.slow
How hard would it be to get a 3 way cigarette lighter outlet and put it in one of the storage compartments in the trunk of the 95?
It wouldn't be too hard, they're easy to find, inexpensive, and not big or heavy. :D
Run something like 12 gauge wire so it will support a large load should the need arise, and fuse it at the battery.
Be sure to use a rubber grommet in the hole where you run it thru the firewall (to prevent rubbing thru the insulation and shorting out) or wrap a couple of layers of electrical tape around the wire there.
Hardest part is probably running the wire thru the vehicle.
