cleaning maf in a '99-in process as we speak
theizzardking
quick question as i got everything pulled apart right now and am doing, plugs,wires,maf cleaning,tb cleaning and throttle cable adjustment
my question is when cleaning the maf shown in this write up
4Runners.org - Cleaning Your Throttle Body and MAF
or this pic
he states
Clean wires (W) and spray into the large hole as well
my question is do you also spray it down the long tube back towards the connector ?
is looks very dirty back in the depths of the MAF closest to where the connector clips on....
GOOD IDEA or BAD IDEA?
i would of course do this from a vertical position so it doesn't pool at the back of the MAF...
it def. looks as if the air gets channeled deep into this parts of the unit but am unsure if i'm going to cost myself 150 bucks by going over board with the cleaning
just hanging out getting ready to put everything back together and quick help would be great
or this pic
he states
if you're using electrical contact cleaner or Maf cleaner, spray the shiit out of it.
Let it airdry afterwards, maybe wipe the plastic a bit but leave the wires alone.
Reinstall :)
Reinstall :)
sweet another quick question if i got the dieelectric grease on top of my spark plugs they should be fine right?not on the electrode but on the end that has the boot, i got a bunch of the grease in one by accident, i don't think thats a big deal as it's the same stuff you use on your battery terminals and your body for ultra sounds...right?....RIGHT?!?!?!
lol
thanks man, i was unsing some of your past threads to help me out here, it's good to have you chime in and clarify, "rep" points coming your way ;-) (if you care, lol)
i should also say i've never used the dieelecttric grease before, never have taken this good of care of anything i owned, 'cept maybe the wife, lol
and the write up shows just putting on the outter flange as opposed to inside the boot.
i thought the purpose of the grease was to keep from frying contacts and corrosion inside the boot.....
the write up is confusing, post pics from write in the next post
Put some dielectric grease on the underside of the coil pack's boot covers
"After installing the plug, clean the bottom of coil pack boot with your Simple Green'd cloth and then put a bead of dielectric grease on the rubber boot surface."
confusing as i always thought it went inside the boot
Yes you want to spray inside that tube. And yes it is ok to get dielectric on the spark plug ends that the wire connects to. Since I have a 99 you may want to check my write up and pics as well.
Toyota 4Runner Highlander Mass Air Flow Sensor MAF cleaning
Toyota 4Runner Highlander Throttle Body cleaning and O Gasket Mod
lol ha! i was trying to find your write up page nut forgot your screen name, i just always knew that page as the the sweet '99 faq and sway bar part number page, FYI love the page you compiled, i use it frequently but have the bookmark on my work computer so didn't know the name, thanks alot man and thanks for jumping in here!!
lol
Hahah thanks dude, glad to be of help
Glad JA cleared that up, I have some dielectric grease and I've only used it on my CB antenna mount so i didnt know lol.
