Cleaning the Engine Compartment
michael90630
Does anyone routinely clean the engine compartment of your 4Runner by washing it? I would like to keep it clean but afraid if any electrical or any other parts will get wet. In my previous vehicle I used to cover up the alternator and some other electrical connections with plastic bags before washing it down.
I recently saw a weekly auto show on TV where the guy recommended using a high pressure washer to clean engine compartments with engine degreaser.
That's what I have done in the past and never had a problem. I wash everything and don't cover anything up and I've never had a car not start for me afterwards. I haven't washed the engine compartment in my 4R yet, but I have no reason to believe my 4R would be any different.
Gunk engine degreaser is a couple bucks at most auto parts stores. Use a whole can per wash. It works great.
Just be careful where you aim the high pressure spray and keep it from directly hitting electronics and use a good degreraser.
Thanks G.I.G & RonMAIDEN
This was good web-site for engine compartment cleaning after I did a Google search on this topic:
http://www.autopia-carcare.com/inf-engine.html
Never tried alum. foil to cover sensitive parts, ArmourAll for shine or use air compressor to dry after rinsing.
The only headache is the Engine Degreaser is supposed to be disposed off correctly. That means need something under the engine to collect the water for disposal.
There is no benefit in washing engine, besides all you can get to are plastic covers and shields. I would never power wash anything on the car especially in the engine bay.
I agree.
I routinely pressure wash all my vehicles engine bays. Every vehicle I have EVER owned, I pressure wash the engine bay, and occasionally will roll around on the wet ground to pressure wash the undercarriage and transmission/oil pan/backside of the brakes, differential, etc.
NEVER have had a problem. Been doing this since 96 when I got my first new truck, a 96 F-150.
I usually use some simple green to spray down the engine bay, let it set about ten minutes, then just pressure wash it off. When done and dry, use some CD-2 Engine Detailer spray and coat the entire engine bay, fender to fender, firewall to radiator. This stuff kicks ass, it shines up the engine bay, and seals everything off from being stained with dirt and road film. After a while, dirt will start to stick to it, but the detailer makes it super easy to power wash it all back off again with a little simple green, and you just re-spray the engine bay down and you're done. Looks like a show car under there, and alot nicer to work around because you are not dirty up to your elbows if you do any work under there.
All electrical connections on newer cars are water tight, and usually have a two, three, or more rubber lip sealing the connector from the elements. And since these things dont use a distributor, that's the only thing you'd ever have a chance of having problems with due to moisture, yet my Rams, my 96 Integra GSR, and my old F-150 that I long since traded off, all had distributor ignitions, and I routinely pressure washed the engine bay, and never, ever had a problem.
I spray mine down with Simple Green and the hose off. Then I drive around for about 10 minutes so the engine is warm enough to dry everything off. Made the mistake once of hosing it off and leaving it. The water spots will cause the aluminum to oxidize.
I agree with Uneek. I spray the engine compartment down with Simple Green then use a soft brush on the plastic parts and then rinse off. I'll run the truck for a few minutes to dry off the engine.
Maybe I'm not the car buff I used to be, but unless you have some mods under the hood worth showing off, I don't really see the benefit to pressure washing the engine. You're not decreasing the drag through the wind, if there is any cooling benefit it is very minor... I tend to wipe things down, rinse with the hose after being in the mud or lots of dirt, but for normal street use and the normal road grime, I think there is more potential to do harm than good... Just my opinion....
I have been fine with using a damp cloth from drying off my 4Runner after a wash. I just take the damp cloth to the engine bay and while it is a bit more work I am less concerned about any possible damage a power washer may cause...
A dirty engine runs hotter and looks like crap when you open the hood and a clean engine is nice to work on and you can spot a leak easier.
I never use full pressure at a car wash but a little sprayer connected tro the garden hose applies decent pressure and I avoid any electronic goodies.
I spray everything down with Simple Green then use a brush on the harder to remove dirt and grime.
There are no plastic covers on the 3rd gens tho'.
4Runneretc013.jpg~original
I've been cleaning the engine compartment of every car I've owned, at the car wash with the pressure hose and in the driveway with simple green and the hose. That goes for every 4x4 listed in my signature, a 78 Camaro, and a 90 Grand Prix STE Turbo. Never any problems and it's a whole lot more pleasant to work on. Cleaning regularly also helps you notice things needing attention. I can't imagine NOT cleaning the engine compartment after 4 wheeling in the mud or beach sand. I've got over 500,000 miles on the 4x4's in my driveway and over 230,000 on the Honda Accord my son took to college and the engine compartments are clean on all of them.
4by4th
Just curious - what happened to your 2004 T4R that it needed a engine replacement?
Was it unique situation or all us owning 4th gen T4R's should be aware because it is a desing/manufacturing issue?
Back in early years of T4R, blown engine head gaskets were a common problem which Toyota eventually fixed with a major recall/TSB.
Re: 4by4th
Didn't you read the thread that's linked in his signature??
Anyone ever took their hood off and go through a brushless car wash to clean their engine bay that way? Just curious.
