Clear-Coat Safe Buffing/Polishing Compound?
not sure if they still make it (or maybe someone else does now)...
Clearcoat rubbing compound by Turtle wax.
It is a very fine abrasive cleaner...a white paste, comes in a white plastic container (at least it did when I bought it 5 years ago...)
I've never used it on my 4runner, but have use it on my Olds with decent results...
Whatever you do, don't use the red/brown rubbing compounds...it will strip the clear coat right off.
I believe 3M makes some products safe for clear coat...but never tried it...
http://www.autogeek.net/3mperllrubco.html
Not sure what you are planning to do...but if you are just trying to smooth out the finish, you might want to start out with a clay bar...
You probably should go here and read/ask:
http://autopia.org/forum/forumdisplay.php?f=58
That said, Griot's Garage makes a good line of products:
http://www.griotsgarage.com/catalog.jsp?L1=L1_1000&L2=L2_1004
If you want a hand polish then this Griot's product is good:
http://www.griotsgarage.com/catalog.jsp?&SKU=11374
I used it on my '98 Camry with good results.
If you want a machine polish then Griot's has that also:
http://www.griotsgarage.com/catalog.jsp?L2=L2_1004&L1=L1_1000&L2=L2_1004&L1=L1_1000&Page=2
But then you would also want a random orbital buffer and you can get a much better price on that from places other than Griot's.
If you read over at Autopia you will find that there are a number of other brands that many people use - Poor Boys, Menzerna etc.
I would stay away from anything called a "rubbing" compound this generally means it is for use during painting when you want to level a coat before applying another; they will leave a severe haze on your clearcoat if not just burn right through it.
