Clicking Noise
4Evr4RunN3R
Hello everybody, I have noticed a clicking/loud ping when my I make a turn using my 4WD. I have tried searching on the forum but haven't had any luck as to what it could be. Any ideas on what it could be? Should I be concerned?
OK, if you are making a turn in 4WD on any kind of hard surface with most 4WD systems you will have noises. Exactly under what conditions does this happen?
If it is a constant rotational clicking it is probably a CV. Mine did it for while, but went away. They have since been wheeled on hard and are still holding
It does it on a slippery surface. I've noticed it this past winter on snow. I'll check for the noise by engaging 4WD on rainy days. Im almost at full turn when it makes the noise. Either taking a hard left or right on a slippery surface will cause it.
Mike Sargent
