Clicking Sound
subzero
Ok, as some of you saw in my other post, I recently discovered that my truck was almost out of oil just at 3000 miles. I thought to check the oil because on that particular day, the engine would fire up for around 1 second and then just die. When I went to start it again, it would fire up fine. This happened twice before I found the problem and I put around 2 quarts in to get the oil line up to the top dot on the dipstick. Well now, 2 days later, I have noticed that when the truck is cold, the engine makes a very slight clicking sound. This may have been happening since I got the truck, and I just now noticed. It only clicks for around 2 minutes unitl the engine is warm. Is this normal??? Is the engine ruined??
Is it a "ticking" sound? If so, then maybe a cracked exhaust manifold. This usually doesn't happen until @ 100K mi, though.
