Clunking on full turns...
cknsls@adelphia
I have an '05 4Runner Sport. When I make a tight turn I get a loud "clunk" from the front end. Any ideas on what is causing this? I replaced the Dunflops with the Michelin Cross Terrains, but they are the stock size.
Any suggestions before I go to the dealer?
clunking
Neither my wife's 04 V-8 nor my 06 clunk on turns and one reason I've thought the 4R seems of higher quality. However, my 02 Explorer did clunk when turning and I understand this is normal with a lot of 4x4s. You might want to have the front drive and turning gear checked.
Great another thing to look forward to ....lol
I'll add that to the normal list of the rear end clunk , rattle over bumps in front end , stink when back window down.
Re: clunking
cknsls@adelphia said:
Forgot to mention...it's a 2WD model. Wife and I went shopping today, tight turn into a parking space at the Mall..."CLUNK!"
I went underneath my 4Runner and looked at the bump stops. No lube at all on them from Toyota, a good coat of rust on both. In the rust were a couple of shiny spots with a sort of downward streak of shiny metal.
This makes me think that it is sort of like the typical California earthquake called (IIRC) a strike-slip. I believe that on the 4Runners that the inital hard contact of the metal-to-metal has very high coefficient of friction and that when there is enough force to overcome it you get a slip that results in the loud clunk.
Mine had started doing this in the last couple of months and yesterday I gave the metal surfaces a light coat of lithium grease. So far, I have been unable to repeat the previous "clunk" sound.
