Clutch chatter on cold days
texadelphia
I've noticed that on cold mornings I have a hard time starting from a stop without the clutch chattering. Anyone else noticed this on theirs?
Sent from my moto g(7) power using Tapatalk
No as that's not normal. How many miles on your clutch and pressure plate
Sent from my SM-A536V using Tapatalk
Based on past experience with Toyota and other fine brands of vehicle, clutch chatter, once established, never gets better, only gets worse, and the driver has to define how much chatter he/she is willing to live with. My current clutch chatters a little bit, on rare occasions, usually when hot. But it is old, has bearing noise, and has at least 120K miles on it, 30-50K of which was with the PO... who I suspect was a heavy clutch user/abuser.
No idea how many miles are on the clutch. It's had a tendency to chatter when cold/wet outside since I bought it 2 years ago. Seems to come and go.
You don't have any leaks as it can be caused by contamination if the clutch surface. Along with a warped clutch surface on the flywheel. ( or clutch material stuck to the flywheel surface) Missing broken bell housing bolts. Cracked bell housing etc.
Freddygino324
