Clutch release bearing issues.
Bad_Vision
Moderator
So with all the crazy information rolling around in my head I am having a heck of a time sorting out what could be causing my throwout bearing on the TDI swap to go bad instantly.
I attached a few pictures for you guys to see the damage caused by the bearings, any insight would be helpful.
i assume the bearing fits over the input collar, rather than binds tight to it and thus not spin?
Yes it's a free floating unit so the only way I see it slamming the clutch tongues like​ that is if the slave cylinder didn't let it return to home position but that's not possible as it's a simple lever. I'm stumped I'll be putting a new bearing in tomorrow morning and I'll grease the shafts and pivot points good but I'm at a loss to what caused it.
Sent from my XT1635-01 using Tapatalk
how about depth? is the bearing being jammed to the back of the collar because there isn't any clearance between the clutch and transmission?
I just have to ask: you don't drive with your foot resting on the clutch pedal right?
To cause that damage, something ISNT spinning at some point. Must have made a terrible racket huh?
That quill (hollow shaft) sticking out of the transmission looks to be in fairly rough shape. The TB slides on that, and I doubt it's sliding freely with that much corrosion, dirt, and rust on it. I would clean that up down to bright metal and make sure the TB slides freely all the way to the back.
We have a winner I think. After cleaning up the shaft and putting a little grease on the inner side of the new throwout bearing careful install it is silent and working perfectly.
