Clutch sound
GSMNP125
Need help!
The clutch is making a "TING" sound when I release it from a stand still. I don't hear it when I switch gears. I replaced the clutch slave and hubs about a year ago. Had to run it in 4 WD for a while but I don't think it's the springs in the hubs.
What-cha think it is?
It's possible that it could be your clutch, sounds more like the carrier bearing in the rear diff. I have the same exact sound when starting from a dead stop, but I can also make it happen at low speed if I let it coast then go into 2nd and give it gas.
My pedal clicks when I release at about the halfway point.
You said you only hear it when you start from a dead stop right? Not when shifting at all? Check your U-Joints first. I've had trouble with them in the past and from your description sounded similar. Check those first. It would definitely cost a lot less to replace.
