Thanks for all the tips and very interesting about the tweeter channels. I thought they looked like just full range speakers - like a bose. I installed the front speakers last night. I'd say fishing the wires through to the door was the hardest part. I'll post some picks at some point. I'll need to put some more sound deadening in there. I used the eDead paint which worked well in the back but didn't seem to work as well in the front. Different frequency range I guess since you're only blocking sub bass in the back. Have to get the plastic from rattling too. It only rattles a bit on certain notes but still annoying.
Love the sound. I'm doing this sort of on the cheap but it's sounding great.
HU: Pioneer 4100DVD
Front: Polk MM 6501 components
Rear: probably matching coax
Sub: JL Stealthbox
Main Amp: Eclipse EA4100
Mono Amp: Eclipse XA1000
Wires: RockFos 4guage to fused dist block - 8guage to amps - 8guage ground to another (non-fued) dist block then 4guage grounded to the chassis. (I read you want to ground to the same spot to remove hum, don't know if that's true but I figured it wouldn't hurt if the wires are good.)
Speaker Wire - Scoche 14guage to mains and 12 to sub.
All other hardware and RCA's are Scoche. I think the Scoch stuff is good but the plastic sheilding is way too sticky. The wires don't pull nice and stick together when snaking them places. I ran all the RCA's up the center of the vehicle.
The stealthbox I bought used - it didn't match the color though it was close so I used some SEM vinyl paint to make it match the plastic panels. It looks pretty good, certainly not as soft as original but it's still flexible and just looks a bit more rugged. The amps I got local on Craigslist for $50 each which was a great buy. As for the Polks, they're the ones I just kept going to when I would listen to things. Something about them, they had the voice I was looking for even though others may have been cleaner and more detailed. I almost went with Eclipse but they just didn't move me. They seemed perfect and yet boring if that makes any sense. Focal's and such were out of my range so I never considered them.
