islanderoffroad
Used a paperclip to pull my codes today, neat little trick.
My T4R is reading code 11, which per 4crawler is:
LOSS OF POWER SUPPLY TO ECU
--IGNITION SWITCH/CIRCUIT
--MAIN RELAY/CIRCUIT
--ECU
Obviously I'm hoping I don't need to replace the ECU (though a quick ebay check reveals them to be pretty affordable), but where should I start with this? Where is the ignition switch, main relay, and ecu? Could this be a ground issue? Anyone had this code before? I did a search here and on google and unfortunately did not find very much info on this code.
--ECU
