Coga PA horn
winniesn
I am thinking of installing this horn/pa system. (http://www.cogapa.com/index.htm) I would have to put the wire to the horn through the firewall. Does anyone have any tips/tricks on putting a wire through the firewall? Also, I haven't even looked yet, but where do those rubber holes in the firewall come through into the cabin? Thanks.
apparently, out of the 58 people who viewed this thread, no one has added an amp or anything that has required power and needed to be passed through the firewall?
I would suggest finding a thread that tells you how to pull down the panel below the steering wheel. If you get that down, and have a friend pass the wires through the rubber plugs along the driver's side engine compartment firewall, you should see them pop through into the passenger compartment. Its a trial and error kind of thing- I have passed several wires this way, you just have to guide it in there as best you can, and you should see it come through. There is a rubber sealer inside the passenger compartment- try to pull that to the side a bit, it will be easier to see the wire pass through.
ksneubec is correct. On the drivers side engine bay, there is a rubber wall that you can pass wires through. I have my amp and fog light wiring go through this same location.
goddesszilla
